18 years agobit by bit Data transfer
Hello All.. I have problem in my code. I have created code for transmitting the data bit by bit. i.e.if my input (FCH)=1010101010101010=AAh then I'm Expecting 1010101010101010=AAh at tx_line o...
18 years agoThe statements inside the clock'event block are executed in parallel within a single clock cycle, also an iteration loop. In your example, only the last bit ist actually send. You can increment e. g. a bit counter to transmit one bit per clock cycle or use a shift register that is initially loaded with the parallel data and shifted out one bit each cycle.
