15 years agoBinary to Binary coded deicmal help
Hi guys, I'm having trouble implementing a double dabble algorithm in verilog. These modules are supposed to produce 8bit BCD output from 5bit binary input. However, it seems like the binary ...
15 years agoThanks for the speedy replies!
--- Quote Start --- if you just insert clock only in add3: always @ (posedge clock) --- Quote End --- I tried using CLOCK_50 which I think should work on my DE1? And the display just read 0 --- Quote Start --- Check with pencil and paper! Perhaps you can give a numerical example of what you want to achieve. --- Quote End --- Thats what is driving me absolutely crazy. I have done it hundreds of times on pen and paper and it's work. I'm trying to convert binary like 01011 to 0001 0001. Here's a run through. TENS|ONES|01011 0000|0010|11 SHIFT 3 (no +3) 0000|0101|1 SHIFT 4 (ones is >4 so +3) 0000|1000|1 0001|0001| SHIFT 5 And the 5th shift gives you the BCD!
