15 years agoBinary to Binary coded deicmal help
Hi guys, I'm having trouble implementing a double dabble algorithm in verilog. These modules are supposed to produce 8bit BCD output from 5bit binary input. However, it seems like the binary ...
15 years agoDon't know where you get the algorithm, but it seems not to do what it should. Check with pencil and paper! Perhaps you can give a numerical example of what you want to achieve.
There should be no principle problem to implement the algorithm completely asynchronously.
