15 years agoBinary to Binary coded deicmal help
Hi guys, I'm having trouble implementing a double dabble algorithm in verilog. These modules are supposed to produce 8bit BCD output from 5bit binary input. However, it seems like the binary ...
15 years agoif you just insert clock only in add3:
always @ (posedge clock) ... than that should register the signal assignments and should be ok to make your design synchronous. The clock must be available as input if you are testing actual hardware.
