18 years agoBig numbers of input, output ??
hello everyone, I am a newbie. After trying in 2 days, I can't do a thing to solve the following problem. My mp3 player design requires to transfer 576 integer number ( 576x32 bit ) among ...
18 years ago --- Quote Start --- Note that the ModelSim version provided by Altera has limited SV support. In particular it doesn't support unpacked arrays on module ports. The different SV support between Quartus and ModelSim can be a PITA. This is supposed to change in 8.1, when Quartus would upgrade ModelSim to a much newer version. --- Quote End --- thank you, I will check the supported feature list of SV in Quartus' Handbook
