15 years agoBidirectional, tri-state buffer, VHDL problem
I m working with tg68k mc68k core emulation for FPGA. When i compile code i get 31 ADRESS BUSS pins, also 16 input, and 16 output pins. I need to join those 16 in and out pins to get 16 bidirectional...
15 years agoI found where is the problem ( i think). All is working fine but other missing signals that i need (ADRESS BUSS etc...) are in TG68.vhd file. Also in that file i can see every signal that i used in my code. As i m thinking i need somehow to connect TG68.vhd to my code and reuse signals from that file.
