18 years agoBidirectional IOs in FPGA
Hi, In my project, I have 2 bidirectional IO buses of 32-bit width. I need to connect both of them together for 2-way data transfer. I've tried two options in VHDL: bus1 <= bus2 This...
18 years agoO.K. I see. Your designing something like a 245 bidirectional driver. Then I actually don't understand the reason for the delay. It must have a particulary reason from your design, e. g. available routing resources. Or the routing is influenced by additional logic connected to the bus signals. Can you verify in RTL respectively Technology Map Viewer that the compiler understands your logic right?
