15 years agoBGA Socket Adapters? or 2 FPGAs connected?
Hi guys, I'm doing a university project. I trying to design a board and i'm running into the problem of limiting pins and logic element counts. The university can only mount flat pack st...
15 years agoRemember a while we discussed our approaches with UDP. I went the hardcoded UDP MUX; i haven't developed a way to properly measure speed; but my system drops packets unless i'm on a Gigabit network.
THis means i must be exceeding the 100Mbps. Though i can't fully test speed as I haven't tried cranking it up to have no breaks between packets. Too many tasks on the go for em atm and time is ticking. What SRAM chip are you using? Size and data width. Are you using an SMSC ethernet chip? What width data bus are you using?
