15 years agoBGA Socket Adapters? or 2 FPGAs connected?
Hi guys, I'm doing a university project. I trying to design a board and i'm running into the problem of limiting pins and logic element counts. The university can only mount flat pack st...
15 years agoThanks guys,
What i'm making is a video over ethernet boards and need the following devices: (gpio) 40 pins : Terasic D5M Camera (For TX board) or Terasic LTM Screen for the (RX Board). ~57 Pins: SDRAM 32bits wide. To copy the DE2-115 i would be using 2x64mb chips. ~47 Pins: Ethernet (use the SMSC LAN91C111) _____________________________ Total of 144 Pins. (I'd likely need more fo tidbits here and there) Thats a minumum, i would like more for a VGA chip, but i'll have to perhaps run that on the GPIO. I was looking at using the EP3c240. Which is 240pin with apparently only 128 usable IO. I hope the programming pins are in those excess pins. Is there seriously 112 power, gnd and reserved pins? _________________________________________ I'm in Australia in the case of talking about location
