14 years agoBest way to use 2 phys in a design?
Hello i have two ethernet interfaces each one with it's own phy. In my current design i am using two ALTERA TSE MAC (small mac), TWO SDGMA_TX, two SDGMA_RX and two descriptor memory and it works w...
14 years ago --- Quote Start --- The migration from tse to oc mac is quite simple. Refer to the following page on alteraWiki (thanks to JakobJones) http://www.alterawiki.com/wiki/avalon_opencores_10/100_ethernet_mac_with_interniche_driver Daixiwen already answered the other points, although I'm not aware of Linux support. :confused: In the original post you said your TSE design required 10k --- Quote End --- Yes because it uses 2 sgdma rx (1600) 2 tx (2400 ) 2 tse (6k) :) I will take a look in the OC one, thanks.
