14 years agoBest way to use 2 phys in a design?
Hello i have two ethernet interfaces each one with it's own phy. In my current design i am using two ALTERA TSE MAC (small mac), TWO SDGMA_TX, two SDGMA_RX and two descriptor memory and it works w...
14 years ago --- Quote Start --- Ok but do you also use two sgdma (rx and tx) for each opencore mac? How is the migration from altera tse mac for opencores? Does it have linux support? --- Quote End --- The migration from tse to oc mac is quite simple. Refer to the following page on alteraWiki (thanks to JakobJones) http://www.alterawiki.com/wiki/avalon_opencores_10/100_ethernet_mac_with_interniche_driver Daixiwen already answered the other points, although I'm not aware of Linux support. --- Quote Start --- plus it really wouldnt change much since 2 opencores mac* 2500 = 5k and i am using 6k with two altera tse mac --- Quote End --- :confused: In the original post you said your TSE design required 10k
