EPrec's avatar
EPrec
7 years ago
Basic VHDL arithmetic not working on std_logic_vectors in Altera (vs Xilinx)
I am porting code that works on a Xilinx FPGA to an Altera FPGA. In my code, I use basic arithmetic operations on std_logic_vectors. As an example, I define the following libraries in my VHDL file:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.NUMERIC_STD.ALL;
Then if I define a signal:
signal my_signal : std_logic_vector(4 downto 0);
And then have a statement:
my_signal <= my_signal - 1;
On the FPGA, this statement seems to be impacting only bit 0 of my_signal instead of the entire vector. I've tried to rewrite the statement as:
my_signal <= std_logic_vector(unsigned(my_signal) - 1);
but that is throwing off errors when I try to build the project.
In Xilinx FPGA, the above statement works just fine, counting down the std_logic_vector (and turning over to 0b11111 when I subtract 1 from 0b00000). Why is this not working on the Intel/Altera FPGA?
