10 years agoavalon streaming pipeline and ready cycles
Hello, Good day! hope you are all doing great!! :) I have a problem of creating avalon streaming component. Building piplelined delayed component that has both source and sink ports an...
10 years agoHello Ghazis,
As long as you follow the avalon st specifications (google avalon specifications), qsys will make sure the timing is correct between the interfaces. The parameters entered when creating the component is what qsys uses to meet the synchronization. If those are wrong, you will have problems. Overall, you dont need to pipeline since it does it for you --Trukng
