18 years agoAvalon Slave Port
Hello to all, I have a Stratix II dev Kit and I made a design with a Nios II, an onchip memory, a tristate bridge and a custom "Typical Avalon MM-Slave" added with the template on SOPC Builder 7.2...
18 years agoThanks for your answer,
my real intent is not to flashing leds, what I need is to put out from the FPGA some signal in a tristate way. I actually use leds to test the port. http://farm3.static.flickr.com/2061/2056994755_ccb1ab4b83_o.jpg As I said writing on port (that I created w/o any file) doesn't give any result. I don't think that IOWR(MY_AV_SLAVE_INST_BASE,0,led) is the correct way to send data to my peripheral.. Thank you very much, Dave
