17 years agoAvalon MM preformance
I just started to play with NIOS2 and its parts, and after I could get my_first_niosII.. to work, I was curious about how is the speed of pheriperials, for example the uC like PIO. This one is very s...
17 years agoExchanging data through an Avalon MM interface is not the fastest way. The CPU looses a lot of cycles fetching the data and writing it back. If you need a fast parallel interface, you should rather use an Avalon Stream interface.
Have a look at the SGDMA component to read/write data from memory to an Avalon stream.
