10 years agoAvalon MM Master Templates
I'm trying to implement a frame buffer using DDR3 memory on a Stratix IV board. I'm using the Avalon-MM master templates which I downloaded from the Altera website(https://www.altera.com/support/supp...
10 years agoIn the document "Avalon_MM_Masters_Readme.pdf" that came with the templates there is a section "Installation" which describes what you need to do. Basically, get the ip/ subdirectory so that it is the ip/ subdirectory of your current project. If your project is in a directory "foo", then if you have followed the instructions you should have a directory "foo/ip/Master_Template"
Then restart Qsys and in the left margin "Component Library" pane you should have Project->Templates->master_template component which you should be able to instantiate.
