8 years agoAvalon interface verification problem
Hello good people, I have a test program which is simply some procedure to write data in avalon master bfm and will read it in an avalon slave bfm. The compilation is done without any error but in t...
8 years agoIf these are two separate BFMs, they should have two separate BFM IDs. You are using 0 for both. That's one issue. I don't know if it's the main issue you have but it could be.
