13 years agoAvalon interface and Network on Chip Architecture, how are they related
I understand that in Qsys, components are connected through the use of Avalon interface. What I am confused about is, where does NoC come on stage and what is the relationship between NoC and Avalon?...
13 years agoHello Matrixofdynamism,
As the other posters have mentioned, NoC can be complex to describe in intricate detail. The bottom line is that it allows the system to make different design choices between the bus standard that is being used, and the interconnect between them. NoC will translate an Avalon or AXI transaction into a wide packet-based stream and route this through the interconnect to the targeted slave. With the different burst sizes and clock domains that may be used in a custom design, a NoC is not static, and will be created on-the-fly to match the required interconnect topology. Great to hear that you are joining the Altera team soon. Please direct message me your contact details, and I'll arrange to add this to your training. Regards Kris
