18 years agoAuto-sensing voltage level shifters
I need to connect some 5V logic to FPGA devices that are not 5V tolerant. I checked different possibilites and found those "newer" auto-sensing dual-rail transcievers. Somebody have any experie...
18 years agoAs the said transceivers (as far as I know, you should tell the intended type to allow a specific check) are basically switches with voltage limiting characteristic, they won't improve noise margin. Also the drive current must be delivered by the primary source. I think that a chance to repeat a signal should be used to improve signal quality, particularly with cables. For longer distance interfaces, I would try to use differential signaling where possible.
