18 years agoAudio ADCDAT not output-able?
If I hook up AUD_ADCDAT directly to an LED, nothing displays. From my understanding, AUD_ADCDAT should be a serial input of one bit of a 24 bit audio interface (with 8 bits for the audio data)....
18 years agoAn audio codec in many cases need an initialization through it's control interface to start operation. If your question is related to audio codec of DE2 board, yes it needs initialization. You have Verilog examples shpped with the board respectively available from Terasic support pages that operate the codec. Alternatively you can design an interface following the datasheet specifications.
