13 years agoAsynchronous Signal
Hi. I have a problem that my FPGA design failing after several seconds. The code purposes isto measurement frequency from external signal generator (50kHz)*. I'm working with 50Mhz clock, LPM_Divi...
13 years agoHi,
Thank you all for your quick response! For conclusion: whether I run into timing problem or whether it's metastability problem, both of them should be dissipating if I'll use at least three synchronization register before I'll use the external data on my design. Am I right? (Assuming, of course, that the design logic sustain it…) Thanks, Idan
