13 years agoAsynchronous Signal
Hi. I have a problem that my FPGA design failing after several seconds. The code purposes isto measurement frequency from external signal generator (50kHz)*. I'm working with 50Mhz clock, LPM_Divi...
13 years agoYou should also check that your synthesizer has recognized your state machine properly (use the rx viewer/state machine viewer). Sometimes if it can't recognize a state machine due to coding issues, you can get some unexpected results.
