13 years agoAsynchronous Signal
Hi. I have a problem that my FPGA design failing after several seconds. The code purposes isto measurement frequency from external signal generator (50kHz)*. I'm working with 50Mhz clock, LPM_Divi...
13 years agoThis thread seems to offer some information for you to look at. The problem is with asynchronous signals you have metastability. When you register the external signal you help improve this which eliminates your problems. I believe there is a document link in the thread which discusses it in further detail.
http://www.alteraforum.com/forum/showthread.php?t=39099
