15 years agoAsynchronous data
hi agin, I whant to clock in data at the rate of 48MHz (Camera). At the falling edge of the PIX_CLK data is valid. My design will work at 48MHz but the both clk's wont be synchronised...
15 years agoIf both freq's are 48MHz will i miss data? Even the fifo add's
latency of 2 clk's? Edit: I wont miss data. You are talking about continuous data stream. Srry It's no problem if i don't have a continuous data stream. I use the FIFO as async. clk's and the nFIFO_EMPTY as DATA_VALID.
