17 years agoAssuming node "clk" is an undefined clock
Hi, yes I have defined a clock for "clk", as you see in the picture. I have another project with the same settings and it works. Don't know what is wrong. Maybe someone had the same issue and ...
10 years agoYou need to write an SDC file to constrain your design. At a minimum it defines the clock, but also things like false paths, multicycle paths, IO delays etc.. Read this tutorial here:
https://www.altera.com/en_us/pdfs/literature/ug/ug_tq_tutorial.pdf
