17 years agoAssuming node "clk" is an undefined clock
Hi, yes I have defined a clock for "clk", as you see in the picture. I have another project with the same settings and it works. Don't know what is wrong. Maybe someone had the same issue and ...
17 years agoI'm sorry, it's solved:
under ..\More Timing Settings\Ignore Clock Settings should be set to OFF !!
