14 years agoASMI clk_in frequencies
I am using ASMI_PARALLEL core in a Cyclone III device. I am using ECPS16 device. Boot area: 0x000000 - 0x080000 Temp area: 0x080000 - 0x0F0000 What I do in my FSM is first store the upload firmware image to the temp area and when it has completely been received I verify the checksum and copy it to the boot area. Writing to the boot area is for me the critical window and my interest is to minimize it. For this I have tried several clk_in frequencies for the alt_asmi core, but somehow the results don't look consistent. The critical window means: 1. erase 8 sectors of the boot area 2. read blocks from temp area one by one and write them to the boot area (256 bytes at once) These are the results I got with various clock frequencies for the ASMI: 10.0 MHz => 16 sec 12.5 MHz => 14 sec 15.0 MHz => 14 sec 16.6 MHz => 12 sec 18.7 MHz => 24 sec 20.0 MHz => 34 sec 25.0 MHz => 34 sec The userguide of the asmi core says 25 MHz is the maximum frequency (supported only in fast read mode). Could anyone give me a hint why these numbers look like this? I was expecting some linear decrease of erase/copy time in relation with the input clock. Thanks!2 Replies
The issue is happening only when using byte-write mode. I have changed to page-write mode and the critical window duration scaled as expected.
For guys still wanting to use byte write mode, perhaps the Verilog model works better (I haven't tried it, but would have been my next step) - Altera_Forum
I have captured some interesting image with SignalTap. It looks like after 32 written bytes the busy of the ASMI starts coming veeeery late.
I believe this is my issue. Does anybody have a clue why this happens? Thanks!
