18 years agoArriaGX compile times
Hi everyone, I'm working on an ArriaGX-based design and have been getting obscene compile times (2-3hrs usually, 30mins-1hr w/ NO changes since last compile & full incremental compile on). ...
18 years agoAlso, if you have tight timing constraints, it will increase your fitter times. Sometimes you can dramatically reduce the fitter time by using pipelining, cut-paths, etc. I've seen where having too much combinational logic between registers will cause the fitter to work harder(more time) to try to make timing. If your only at 60% LE usage, try setting optimization to speed.
