alreadyexistusername
5 years agoarria10 maximum current consumption
what is arria10 maximum core current comsumption in operating range??
+-30mv voltage margin in operating range..
but there is not data about operating current range..
i had asked technical supporter about max current(@core 0.9v)..
i had get answer that please refer EPE result.
so i had tried to find max current comsumption as EPE..
but EPE show me 300A at core 0.9V!!!!
300A current comsumption is impossible.. is it??
EPE isn't consider current consumption....
maybe EPE just calculating tool about power. about heating and cooling....is it?
so.. how do i get max current consumption value in "OPERATING RANGE"???
please see attatchment file..it is intel i7 datasheet..
10A current consumption make 33mV voltage drop..
and... arria10 operating voltage margin is +-30mV(@0.9V core)
it means arria10 max current consumption is under 10A... is it??
- EngWei_O_Intel
Hi there
EPE is the correct tools. Referring to documentation below:
You can view the various current spec in the report tab, which I glance thru it and quick check the Total current is in mA range.
- alreadyexistusername
i had wrote above... EPE result was 300A..
is it possible to 300A current draw within +-30mV operationg voltage margin??
