JoelCaruso
6 years agoArria V Starter kit - Simple Socket Server (RGMII) how to address DHCP failures?
Posting on behalf of Metron Inc. - Jeff Need support with the Nios Simple Socket Server (RGMII) example. I’ve found no posts on the forum that describe what I’m seeing. Here is what I see: I ha...
Deshi_Intel
6 years agoHI,
May I know which Intel FPGA Ethernet IP that face the problem here ?
Did you managed to isolate the issue further to Ethernet IP block ? Like is this high level software application issue ? board connectivity or setup issue ?
Have you tried with Ethernet IP internal loopback feature to isolate potential failure point from external factor ?
Can you duplicate the issue to Ethernet MAC and PHY layer only to check is the Eternet IP behaving correctly ? To isolate is it Ethernet IP bug, setting or other user design issue ?
dlim
