10 years agoArria V FPGA RF Development Kit: Does Not have any SMA GPIO I/O OUTPUT
Hello Altera Forum guys, I was wondering if someone can provide me an advise for this issue, currently i have a code for implemented a trigger from the FPGA to send outside using an SMA or S...
10 years agoThe board should have come with a HSMC breakout adapter which connects some of the pins out to a 2.54mm header. That is your other option as it allows you to use the corresponding GPIO pins.
