10 years agoArria V FPGA RF Development Kit: Does Not have any SMA GPIO I/O OUTPUT
Hello Altera Forum guys, I was wondering if someone can provide me an advise for this issue, currently i have a code for implemented a trigger from the FPGA to send outside using an SMA or S...
10 years agoi tried several times placing in the TX SMA Pin Assignments:
Transmitter Pin Assigments SMA_A_TX_R17_N B4 LVDS or 2.5-V Transceiver channel SMA_A_TX_R17_P B3 LVDS or 2.5-V Transceiver channel Unfortunately after run the compilation i received an error: ): I/O pin triggerout_sma with Termination logic option setting Series 50 Ohm without Calibration cannot be placed inside I/O Bank B0R because the I/O bank does not support the requested Termination setting -- Alex
