10 years agoArria V FPGA RF Development Kit: Does Not have any SMA GPIO I/O OUTPUT
Hello Altera Forum guys, I was wondering if someone can provide me an advise for this issue, currently i have a code for implemented a trigger from the FPGA to send outside using an SMA or S...
10 years agoI think you can use those pins simply for logic and use the SMA connector. You do not use the transceiver channels. This can be checked by assigning those pins to your design ports. If Quartus was happy with that, then it should work.
