14 years ago
Arria II problem-short circuited between VCCA_PLL and GND
hello everyone:
i'v got a problem about Arria II EP2AGX45-C6
recently, i'v got 8 pcs EP2AGX45 board can't work, I test and find +2.5V is shorted to GND in all these boards, and the FPGA was the root cause.
FPGA's VCCA_PLL pins E6/Y6/F17/W17 was shorted-circuit to its GND pin B5
the impedance is only about 0.3ohm or 19ohm
The impedance between VCCA_PLL pin and its GND pin is at least 10Kohm in normal FPGA
I guess there should be some EOS porblems
Then I write a test code to make the board repeat working for 30 minutes then power down for 5 seconds, run this case 5 days and the oscillograph get nothing about overshoot or undershoot on +2.5V power domain during power on/ working/power off
I was confused about the cause of FPGA's PLL power pin shorted-circuit to GND
how could that happened?
By the way: 4 DDR2 chips connected to top and right bank of FPGA runs at 267MHz in half-rate mode, that's a violation, because EP2AGX45-C6 only can supports 200Mhz max clock rate with 4 ddr2 chips.
It this the cause?
    hi,
    did you find the cause of FPGA's PLL power pin shorted-circuit to GND
    we have 2 boards here with same problem.
    regards,
    Arvind.
    Hello JoeyBao,
    please I have a question, if you solved the problem, because we have a similar problem on a few pieces of Arria II GX EP2AGX65DF25C6.
    Thank you very much for your answer.
