15 years agoARRIA II GZ problem
The ARRIA II GZ device handbook says that the nCONFIG and nSTATUS to be pulled up to VCCPGM at 3V for ARRIA II GZ device . The page number in the handbook is 318 . Now my question is why is it speci...
15 years agoOther parts of the documentation state that the VCCPGM line can be at 1.8, 2.5 or 3.0V so I don't see any reason why you couldn't use 2.5V for your pull-ups. It looks like all the configuration schemes that use an EPCS flash in that documentation mention this 3.0V voltage level, probably because the flash doesn't support a 2.5V supply and Altera is afraid of overshoots with a 3.3V supply. On page 318 (9-34) it could just be a bad copy/paste.
DEV_OE is an optional function, and will be used only if you enable it in the device options window. By default it is disabled and you can use this pin as a regular I/O.
