15 years agoArria II GX devkit - PCIe Qsys
Hi Using Arria II GX dev kit Trying to run ref design from following but couldn't get is working. http://www.alterawiki.com/wiki/pci_express_in_qsys_example_designs I using Quatu...
15 years agohum...sounds unusual.
If the high-pef work, this design should work. I don't recall about the LED, but at minimum, PC should recognize it. By the way, the design on wiki is not ref design and will not compatible with the document in some degree. Qsys version and high-pef design is totally different.
