15 years agoArria II GX devkit - PCIe Qsys
Hi Using Arria II GX dev kit Trying to run ref design from following but couldn't get is working. http://www.alterawiki.com/wiki/pci_express_in_qsys_example_designs I using Quatu...
15 years agoYou might need to set the dipsw to select x1, x4, or x8 on the board.
I believe that the board's power switch is on... Both XP 32bit, 64bit should be fine.
