13 years agoArria II GX Altmemphy DDR3 Bit Error problem
Using Quartus II, 10.0, sp 1.191 (yes, I installed the .191 patch for the memory controller problem). Arria II GX EP2AGX45DF29C5 I really hope I can explain this error, it has me pulling my ha...
13 years agoAs of today, 6/13, still have not found the problem, Jheij. I have fallen back to a simple DDR3 only system, writing and reading canned 32 bit data and doing compares. So far I am not seeing any bit errors in simulation or in my design.
I suspect the real issue you and I are seeing is due to a long line somewhere, and my new test system is so small and compact, the fitter has a much easier job. I'll let you know what I find beyond that.
