13 years agoArria 2GX PCI Express RECEIVES WRONG DATA
When I run the default Altera application "Chaining DMA" and send a counter data (2KBytes i.e 0x0000000100000000 - 0x000001FF000001FE ) from the software application side , the data is properly received from 0x0000000100000000 - 0x000000FF000000FE then the sop is valid for more than one pulse , the sop remains high till the rx_valid is high and i lose the data around 20h bytes i.e 0x0000010000000000 - 0x000001200000119 . this keep repeating and is inconsistent. it does vary from lose of 20h bytes and some time 16h bytes.
The IP is generated for ARRIA2GX 260 lane - x1 maximum payload - 256 desired performance for receiving request - MAXIMUM BAR REGISTERS Bar 0 - 32 bit non-prefetchable Bar 1 - 32 bit non-prefetchable Bar 2 - 32 bit non-prefetchable Any idea why the sop is getting corrupted n data lost.. ??No RepliesBe the first to reply
