9 years agoArria 10 SX - The Fitter cannot place logic IO_LANE ???
Hello, Actually, I use a Reflex CES Achilles board with a SoC FPGA Arria 10 (10AS066H4F34E3SG). The board is also equipped with two DDR4 memory (2x8 GB). One of them can be accessible from the ...
8 years agoI use the same Achilles board as joco83. I got the same error when trying to port my design to the board. It may be as sstrell writes that there is an I/O conflict with the HPS I have not looked at the HPS yet. But I noticed that the DDR4 test design from Reflex CES compiles. So I compared assignment from the two project and found some differences. These are the assignments I changes. I do not know which ones are responsible but afterwards the error is gone and the project compiles. Maybe the HPS_EARLY_IO_RELEASE OFF?
-set_global_assignment -name OPTIMIZATION_MODE "HIGH PERFORMANCE EFFORT" +set_global_assignment -name OPTIMIZATION_MODE BALANCED +set_global_assignment -name PROGRAMMABLE_POWER_TECHNOLOGY_SETTING AUTOMATIC +set_global_assignment -name PROJECT_IP_REGENERATION_POLICY NEVER_REGENERATE_IP +set_global_assignment -name VHDL_SHOW_LMF_MAPPING_MESSAGES OFF +set_global_assignment -name PRESERVE_UNUSED_XCVR_CHANNEL ON +set_global_assignment -name ON_CHIP_BITSTREAM_DECOMPRESSION ON +set_global_assignment -name ENABLE_AUTONOMOUS_PCIE_HIP OFF +set_global_assignment -name HPS_EARLY_IO_RELEASE OFF +set_global_assignment -name CVP_MODE OFF +set_global_assignment -name ENABLE_CONFIGURATION_PINS OFF +set_global_assignment -name ENABLE_BOOT_SEL_PIN OFF
