16 years agoAnyone ported AN532 PCIe to Arria2GX dev kit?
Has anyone ported the PCIe reference design for App Note 532 to the Arria II GX dev kit - and had the PC host GUI work? If so, can you share the project or any insight? -Thanks
16 years agoHi Peter,
tahnk you for the answer. My design still doesn't work. I read that i need the reconfig block but it isn't generated and i can't choose PCI reconfig in the Megawizard from the SOPC builder. Where did you get yours? Maybe that's a problem with Quartus 10.0? It's "N/A" - not available. If i start the Megawizard manually the option is available. The pcie reference clock from the motherboard is 100 MHz. Do you confirm that a division by 3 works? I ask, because it's less that 37MHz that you mentioned in your wrapper. Regards, Frederik
