15 years agoaltpll component query
I am using a DE2-115 board with Cyclone IVE. When I design something in SOPC, I just use one external clock input of 50 MHz, and then I use the altpll component in Quartus MegaWizard Plugin Manager t...
15 years agoIf you want to know the maximum system clock frequency your device can work normally. it mainly depends on the device (include fpga and sdram) and the temperature.
You can use eda gate level simulation to see whether your design can work well on your input clock, which provided several models. If you want to know the highest frequency pll can export, I don't know either, but I think it must be higher than your device's maximum input clock.
