ALTLVDS_TX is not able to handle clock tree and assignments during fitting synthesis.
- 6 years ago
I have finally found a way around. I just gave up using LVDS for Stratix V. Instead, I used CMOS and ended up rewriting the HDL. It is now working like a charm, but I still need to fix some minor issues.
With respect to the LVDS, the problem were actually the pins in different banks. It is not possible to "link together" the same clock tree for different banks.
Thanks for everybody feedback!
Best Regards.
Hi ,
Check the IO pins and clock is compact to the Stratix V IO user guidelines. And also check by mistake using the transceiver pins. If using the transceiver pins , the above error will occur
- CFDia7 years ago
Hello RSree,
Thanks for your reply. What do you mean with compact to the Stratix V? Would you mind tell me what is it?
I checked assigment table from Stratix V development board. What else should I check beyond pin assigment and LVDS. I am quite sure that they are correctly assigned.
Is there anything on Megafunction properties that I should change?
- CFDia7 years ago
Thanks for your help. I am looking forward to learn what is the solution. I've been looking for solutions in old posts, but I have no idea on even how to start my debugging.
- Rahul_S_Intel17 years ago
Hi ,
I have done the below for the isolation of the issue.
- Compiled the project in 19.1 Quartus got the fitter Error.
- Made the pin assignment to auto project got successfully compiled. This means to say that the logic is fine
Next action.
Try to isolate the error which pins are making the error.
Initial the hsma_d signal is giving the error, when I try to isolate, another fitter is occurring, So I need time to understand the code and how you have initialized the code to LVDS and PLL ip. Here I feel there should have done some violation.
Let me go through it and I will update you.
- CFDia7 years ago
Here is a sample of the project which results in error. Please, let me know what are your impressions.
Thanks!
