18 years agoaltlvds pll clock timing constraints
Hello, I'm getting a hold slack violation between clock outputs on the PLL used by an altlvds_rx module. clk0 output is 300MHz and clk2 is div 7 or 42.86. My question is, should I be includi...
18 years agoThankyou,
actually, I think there is something in what you have suggested. I seem to remember running derive_pll_clocks in TimeQuest and getting a list of multicycle type messages as well as the list of pll clocks. To be honest, I don't understand them very well but I'll try it again and post the results. It's a SERDES so there is a transfer of a word on every 7th clock cycle. That's why I was unsure whether or not the clocks should be in the same group.
