13 years agoaltera tse mac signal ff_tx_rdy
Hi I am using tse mac ip for ethernet and i am getting rx side of sop & eop properly but i am getting the ff_tx_rdy low. when rx side of sop is always low & eop is properly getting in ...
13 years agoI've never really paied attention to those, just using what Altera put in their driver
IOWR_ALTERA_TSEMAC_RX_ALMOST_EMPTY(tse.mi.base, 8);
IOWR_ALTERA_TSEMAC_RX_ALMOST_FULL(tse.mi.base, 8);
IOWR_ALTERA_TSEMAC_TX_ALMOST_EMPTY(tse.mi.base, 8);
IOWR_ALTERA_TSEMAC_TX_ALMOST_FULL(tse.mi.base, 3);
IOWR_ALTERA_TSEMAC_TX_SECTION_EMPTY(tse.mi.base, tse_hw->tse_tx_depth - 16); //1024/4;
IOWR_ALTERA_TSEMAC_TX_SECTION_FULL(tse.mi.base, 0); //32/4; // start transmit when there are 48 bytes
IOWR_ALTERA_TSEMAC_RX_SECTION_EMPTY(tse.mi.base, tse_hw->tse_rx_depth - 16); //4000/4);
IOWR_ALTERA_TSEMAC_RX_SECTION_FULL(tse.mi.base, 0); It seems that you are using the correct value. I don't really understand how they influence the core's functionality, but the multiple comments on tx_section_full seems to show that Altera isn't sure either ;) It may be a stupid question but are you sure that the tx path is enabled? You can check it by reading Command_config Register. Do you reset the TSE after changing the fifo registers? Altera recommends a reset after a speed change, but it could be useful too when changing the fifo registers.
