9 years agoAltera product for network traffic processing
Hello. Our company is interested in low-latency implementation of some application-level network protocols (say, FIX or FAST financial protocols and/or some other broker firm usages of fpga, e.g....
9 years ago --- Quote Start --- Thank you. So if i want to use Altera ethernet ip core i have also to use Avalon bus core? And my business-logic core has to interact with Avalon bus core (so i need some adapter core)? --- Quote End --- It depends on your implementation, it may or may not be needed. I believe you can use Nios to read back from the memory location that your IP is working on - but with Avalon adapter wrapped around you logic, you have the ability to handle back pressure and manage interrupts. This is just my thoughts - perhaps there are better explanation out there. Meanwhile, if you are using SoC and are running Linux on the ARM core, you can read/write to your FPGA IP via one of the HPS-to-FPGA bridges that uses AXI interface. Hope this helps...
