15 years agoAltera MAXSONAR LVEZ1 sensor
Hi I want to cnnect the LVEZ1 sensor to the de2 board. I have read that the sensor has a serial rs232 format output. But i am not sure how i can connect these to the rs232 module on the de2 boa...
15 years agoThanks.
Should I be using the Nios ii altera's software for this purpose or just have a module function uart and call this function whenever i need to receive data? And also how do i use the I/O voltage as supply? Are the connections I mentioned earlier from sensor to rs232 (de2) look right?
