14 years agoAltera MAX+PLUS II Software - Using the Altera MPU (PL-ASAP2) & LP6 Logic card
Hi Folks, I know this hardware I'm talking about here is obsolete...discontinued Altera Gear from ions ago. I'm a collector of the older Altera Gear. I have all the newer FPGA units also, but t...
14 years agoJust another note to add:
If you have trouble Programming a component with an Altera MPU (Master Programming Unit) and you get a programming Error saying "Device is not Erased"; it's a good idea to verify that the component is NOT a OTP component (One-Time-Programmable). Verify the components datasheet and also check the Part number ordering code to ensure that the component is Electronically Erasable. As shown in the Altera Part number ordering code sheet below: http://www.digital-circuitry.com/images/webpage/mylab/altera/altera_classic_part_numbers.jpg (http://www.digital-circuitry.com/images/webpage/mylab/altera/altera_classic_part_numbers.jpg) I recommend you read through this thread: http://www.alteraforum.com/forum/showthread.php?p=153669#post153669 (http://www.alteraforum.com/forum/showthread.php?p=153669#post153669) Hope this helps. Regards, Gerry O'Brien http://www.digital-circuitry.com (http://www.digital-circuitry.com)RobertFord
2 years agoIf you still need help let me know
