15 years agoALTERA DEVICE WITH THE IOs?
HI, Need help - Is there any Altera device / Ref board that supports the following or as much as possible from the list below? Serial RS232 - 2 Chanels Serial RS422 - 2 Chanels Serial RS485...
15 years agoFor every interface You'll need external chip. Either it is RS232/422/485 (You'll need level shifter) or USB/LAN/CAN... I think all of the devices would fit, which are around 50-70k of LEs. Do a design on a preferred device and check if it fits. I would say try on EP3C55 firstly.
