12 years agoAltera DDR3 Memory Controller and PHY
I am using Altera DDR3 Memory Controller + Uniphy in Stratix V. I have a board with four (4) DDR3 SODIMMs which have been designed to work up to 800 MHz. I have four DDR3 Controller + Uniphy, one for...
12 years agoI wouldn't want to sign of a design with the PLLs being driven by a clock frequency other than the one it was designed for - although it may well work...
You could use an external PLL to source the clock to the FPGA, but the UniPhy would still want to instantiate a PLL for the DDR memory interface. I don't think you'll gain anything, except a design that's trickier to constrain. If you want to try different frequencies, I suggest you regenerate your design. Regards, Alex
